fuedal
Aug 13, 2022Initiate
conecting netgear ext to livebox
Hi Im unable to connect my ac1900 model 6470 to my live box .Ive downloaded the nighthawk app but I keep going round incircles. eg one of the messages i keep receiving tells methat IM CURRENTLY CONN...
Aug 14, 2022Guru - Experienced User
Factory reset the extender (push and hold reset for 7-15 seconds while powered on).
Then follow the installation assistant.
fuedal
Aug 27, 2022Initiate
Thank you for your help but I discovered the problem was my livebox wasn't functioning due to lightning damage new one now installed and working well.
- plemansAug 27, 2022Guru - Experienced User
Glad to hear you got it fixed! You might mark it solved so others aren't still trying to fix it
