Jaxx
Jan 12, 2012Novice
Configuring a default route / gateway - MBRN3000
Hi, Not sure if the title correctly captures what Im trying to do, but basically Im trying to make a work-around so that I can use my LTE connection with the MBRN. I have the LTE dongle connecte...
jmizoguchi
Jan 12, 2012Virtuoso
if you are using MBRN behind the PC as ICS then you are using as AP setup so any rules you create does not apply.
you pc must do all your binding and/or traffic directing.
