Jaxx
Jan 12, 2012Novice
Configuring a default route / gateway - MBRN3000
Hi, Not sure if the title correctly captures what Im trying to do, but basically Im trying to make a work-around so that I can use my LTE connection with the MBRN. I have the LTE dongle connecte...
jmizoguchi
Jan 13, 2012Virtuoso
Just a question though - when I connect to the Wifi and enter a URL, I get a "USB Device missing" error from the MBRN, and not a webpage unavailable message which is what I would expect.
you have to use compatible 3G dongle
Sounds to me like the MBRN is 'hard-wired' to route all ranges outside the local LAN (192.168 range in my case) via the USB device ?
Is is there a config option to change this ?
if you are using 3G dongle on PC's USB and use ethernet port of the the same PC to hook MBRN to do ICS then setup are based on ICS from your PC
MBRN is used as only access point so there isn't much
DHCP disable / sepecify correct IP for MBRN hooking to your pc's ethernet.
