cchps
Aug 06, 2020Aspirant
configuring extender
my browsers redirect http to https, so I can't configure the extender. Does netgear have another option?
Aug 06, 2020Guru - Experienced User
are you following the install guide?
https://www.netgear.com/support/product/WN2500RPv2.aspx
have you tried hardwiring into the extender (disable wifi on whatever device you hardwire in so it doesn't default back to the wireless) for setup?
cchps
I am connecting with an ethernet cable
and am following instructions
- plemansAug 06, 2020Guru - Experienced User
so where is it failing? We're not there to see what error your getting, whats going on, what you're doing, so we need details.
I've done this numerous times and never had an issue.
Have you tried a different pc/laptop? tried a different browser?
Factory reset the extender?
