ramani's avatar
ramani
Follower
Nov 08, 2017
Configuring the extender
Can you please let me know how to configure the extender through the browser. The user name of "admin" and password of "password" does not work at all. Please help. Also, is there a possibility of someone else entering into my network through the extender as the data consumption has suddenly increased after connecting the extender through WPS. I would like to change the password of the extender to try to prevent this .
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    You will have to factory reset the extender by holding the reset button for 10+ seconds then the default login should work for you again and you will be able to change all of those settings.
    DarrenM
