williampeck1958
Feb 18, 2018Aspirant
Confused on EX6200v2 WiFi Extender extending 2G and 5G home networks
This is for AC1200 WiFi Range Extender, Model EX6200v2 For my new FIOS Router I have a Home-2G, Home-5G, and Home-Guest (which is 2.4G). The WiFi Extender works fine, but their networks are Home-2...
- Feb 20, 2018
Hi williampeck1958,
You can try accessing the extenders' UI to verify all the wireless settings and confirm the SSID (WiFi name) of the 5GHz band. You can check page 23 of the user manual linked below.
http://www.downloads.netgear.com/files/GDC/EX6200/EX6200_UM_EN.pdf
Dexter
Community Team
williampeck1958
Feb 19, 2018Aspirant
When I connect with my phone to Home2G_5GEXT, I do not see the 5G indicator lit. So it seems to me that I'm not extending my 5G network.
DexterJB
Feb 20, 2018NETGEAR Moderator
Hi williampeck1958,
Dexter
Community Team
- williampeck1958Feb 20, 2018Aspirant
Dexter, great, thank you! I logged on to www.mywifiext.net. So I see the name for the 5G network and working on changing that now. It's doing a firmware update.
Will check back after this completes.
it's looking good. I don't see the 5G indicator lit up on the WiFi Extender. But I got the name changed and by looking at mywifiext.net I can now see what's going on.
Thanks again!
- DexterJBFeb 21, 2018NETGEAR Moderator
Hi williampeck1958,
Thank you for the update and confirmation. Glad to know you got it working.
Dexter
Community Team
