knute97
Apr 21, 2021Aspirant
Confused
 Hi,     Just installed my AX8 as a range extender and am confused about the status indications.     When I run the Netgear status program , I see that the signal btwn the modem and router is green fo...
- Apr 22, 2021
When you're using it in mesh mode (one wifi), its your device (phone/tablet/laptop) that decides when to roam between the 2.
You can disable the one wifi function if you'd like.
Apr 21, 2021Guru - Experienced User
What actual router do you have?
And what model extender?
(hint AX8 and AX***/AC*** numbers aren't model numbers)
Move the extender further away from the router. 3ft is to close.
You can also try changing the channel the 5ghz is using on the router.
knute97
Thanks for the response.
Reading from the box, it's listed as a Nighthawk AX8.
From the bar code on the box, it shows as EAX80-100NAS. Could find no comparable model number on the drop down list.
- plemansApr 21, 2021Guru - Experienced User
So the extender is the EAX80 (it is the model number)
What router are you connecting it to?
Did you set it up using WPS or using the installation assistant?
- knute97Apr 21, 2021Aspirant
It is connected to Optimum's Sagemcom F@st 5260 router. I set the extender up using the installation assistant.
I wanted to try changing channels, but the Optimum router dashboard does't seem to have the ability to make the change. Am going to investigate this item further with Optimum.
Bottom line, with the WiFi Router link icon red while the 2.4 and 5.0GHz icons are white, am I connected?
Log into the extender and take screen snip of the status page. That shows us the connection info.
