MakiMaki
Nov 09, 2022Aspirant
Connect a Nighthawk EX8000 to an Orbi satellite wirelessly where the RBR20 is in access point mode.
I have in my house a Linksys EA8300 as my main router in the living room towards the front of the house. I also have an Orbi RBR20 hard wired, as an Access Point, to the Linksys EA8300 in the middle ...
- Nov 11, 2022
1. Don't put the ex8000 in the middle of the orbi. The orbi uses a dedicated backhaul that only the router/satellites connect to. Put the ex8000 after the orbi satellites as it can't connect to that dedicated backhaul.
2. you're not going to get what you want. You can set all your devices with the same ssid if you want. That isn't the issue. The issue is they aren't going to roam seamless. Your mixing devices and manufacturers. For sure, set them with the same ssid. but devices will be stick between the netgear equipment and the Linksys. If you wanted seamless roaming, go with the orbi alone and purchase extra satellites. Or make the best of what you have. Set the linksys up as primary with its own ssid/password. Then use the orbi in ap mode with the ex8000 connected to it. Those devices that travel around, have connected to the orbi/ex8000. The stationary ones, have on the linksys.
CrimpOn
Nov 09, 2022Guru - Experienced User
MakiMaki wrote:
I want to have the same Wi-Fi network running throughout my house and yard as I want my Blink cameras to be able to access the same network no matter I have them installed.
Same network is the key requirement, not same "name". The Linksys router is assigning IP addresses to every device that connects to the network, whether over WiFi or by Ethernet cable. They are all in one network. It is sometimes convenient to have some of the WiFi access points broadcast different WiFi SSIDs ("names") For example, if the EX8000 broadcasts the WiFi name "Garage", then devices set up to use that name will never be tempted to connect to the Linksys WiFi or to the Orbi WiFi. But they will still get an IP address from the Linksys and will be in the same IP subnet as every other device in the house.
(This is a one of the solutions for the awkward situation where a 2.4G WiFi device will not connect unless the smartphone app is connected at 2.4G. Create a new network broadcasting only 2.4G. Connect both the phone and device to it. After the device is working correctly, turn on the 5G WiFi from that access point.)
