dvcarbone
May 20, 2022Aspirant
Connect EX6150 Extender to Linksys E9450 Router
I have had the EX6150 for a year and have used it with my Netgear router fine. When I replaced the Netgear router with a Linksys E9450 router, I can't connect the EX6150 to it. I've reset to "factory settings" to start fresh (in fact several times) but the extender will not connect with the Linksys router. Any thoughts?
what error are you getting?
what firmware version are you on?
What method of setup are you using? WPS or the installation assistant?
- dvcarboneAspirantWhen I sign into the extender the message says “The extender can’t connect to the router”. The extender’s Firmware Version is “V1.0.1.108”. I used the Web setup and not the WPS setup. I’m able to get into the extender. It “sees” the router and both os it’s SSID’s, but when I try to connect it trys for a minute or so and then the message appears.
If you're using any special characters or spaces in the ssid/password in your router, remove them.
