dvcarbone
May 20, 2022Aspirant
Connect EX6150 Extender to Linksys E9450 Router
I have had the EX6150 for a year and have used it with my Netgear router fine. When I replaced the Netgear router with a Linksys E9450 router, I can't connect the EX6150 to it. I've reset to "facto...
May 21, 2022Guru - Experienced User
If you're using any special characters or spaces in the ssid/password in your router, remove them.
dvcarbone
May 22, 2022Aspirant
I WAS using special characters in both my SSIDs and passwords. I removed all of them and now they are composed of only letters and numbers. I tried to connect the extender and it still will not work. I tried both the WPS method as well as the Web browser method. Neither worked. My extender is plugged in about 15 feet from the router. I have also reset the extender to "Factory Settings" several times but to no avail. I don't think the router is blocking the MAC addresses, as I don't see the extender MAC address in the client list on my router, unless it rejects the extender and removes the MAC address. Crazy question, but I assume that a Netgear extender can connect to a Linksys router. Right?
- plemansMay 22, 2022Guru - Experienced User
Looks like that router is an "easy mesh" router. Not sure exactly what that entails with linksys but are you able to go into the router and disable that feature?
- dvcarboneMay 23, 2022Aspirant
While there is a Linksys E9450 that has an "EasyMesh" feature, mine is the "Classic" E9450 (I didn't know that until I checked) and it does not have the "EasyMesh" feature. Therefore I can't turn it off.
- plemansMay 23, 2022Guru - Experienced User
there's only 1 version of the e9450.
Linksys Official Support - Dual-Band AX5400 WiFi 6 Router (E9450)
