alexreboot
Mar 06, 2020Aspirant
connect to AC1200 WiFi Range Extender EX6120 but does not have internet
Hi, I installed the AC1200 WiFi Range Extender EX6120, I see two network more, but when I connect to EXT2 (2.4 GZ) I cannot have the Internet connection, but if I connect to network of Router I h...
Mar 09, 2020Guru - Experienced User
wowsa, the dg834gt is an old router from 2004.
you might not even need an extender. you might just need to update the router.
What you could try doing is directly connecting the EX6120 to the dg834gt and run the extender in AP mode. You'll get better performance than trying to connect the extender to that router via wireless.
alexreboot
Mar 09, 2020Aspirant
Thank you for your answer.
Yes, it is an old router. Can you give me an advise: is it better to buy a more recent Modem Router? Which model can you give me as advice?
It is better to change my old router, what it is more better: the tecnology is the same... but better hardware, antennas.
- plemansMar 09, 2020Guru - Experienced User
alexreboot wrote:Thank you for your answer.
Yes, it is an old router. Can you give me an advise: is it better to buy a more recent Modem Router? Which model can you give me as advice?-----check with your isp for what's compatible with your service.
It is better to change my old router, what it is more better: the tecnology is the same... but better hardware, antennas.----are you asking me whats better? I'm unclear. You're basically on wireless G single band technology. (wireless 3). Its went from wireless G--->wireless N (wifi 4)----->wireless AC (wifi 5)----->wireless AX (wifi 6). Its been quite a change from the wireless G device you're on uses.
here's lots more info
https://www.duckware.com/tech/wifi-in-the-us.html
- alexrebootMar 09, 2020AspirantThank you. Some advise for modem router model?
Thank you.- plemansMar 09, 2020Guru - Experienced User
are you looking for an all in one or a modem/router seperate?
The modem aspect of it you need to contact your isp. many have compatibility charts for what works with their services.
