alexreboot
Mar 06, 2020Aspirant
connect to AC1200 WiFi Range Extender EX6120 but does not have internet
Hi, I installed the AC1200 WiFi Range Extender EX6120, I see two network more, but when I connect to EXT2 (2.4 GZ) I cannot have the Internet connection, but if I connect to network of Router I h...
alexreboot
Mar 09, 2020Aspirant
Thank you for your answer.
Yes, it is an old router. Can you give me an advise: is it better to buy a more recent Modem Router? Which model can you give me as advice?
It is better to change my old router, what it is more better: the tecnology is the same... but better hardware, antennas.
Mar 09, 2020Guru - Experienced User
alexreboot wrote:Thank you for your answer.
Yes, it is an old router. Can you give me an advise: is it better to buy a more recent Modem Router? Which model can you give me as advice?-----check with your isp for what's compatible with your service.
It is better to change my old router, what it is more better: the tecnology is the same... but better hardware, antennas.----are you asking me whats better? I'm unclear. You're basically on wireless G single band technology. (wireless 3). Its went from wireless G--->wireless N (wifi 4)----->wireless AC (wifi 5)----->wireless AX (wifi 6). Its been quite a change from the wireless G device you're on uses.
here's lots more info
https://www.duckware.com/tech/wifi-in-the-us.html
- alexrebootMar 09, 2020AspirantThank you. Some advise for modem router model?
Thank you.- plemansMar 09, 2020Guru - Experienced User
are you looking for an all in one or a modem/router seperate?
The modem aspect of it you need to contact your isp. many have compatibility charts for what works with their services.
- alexrebootMar 14, 2020Aspirant
Hi, thank you for you answer.
I am looking for a Modem/Router integrated, together.
what the best in you opinion?
Thank you for your advise.
