Shawngarvey
Jan 07, 2023Follower
Connect to Netgear Extender?
i’m sure this sounds like a novice question: I just hooked up a Netgear nighthawk extender. I’ve got four green lights. I can’t find the new extender to connect to. Am I supposed to connect to my home...
Jan 08, 2023Guru - Experienced User
Like michaelkenward says, what extender model is it?
Some are mesh extenders and if setup using wps or the default settings, will use the same exact ssid as the router.
but if its not a mesh extender, it should have a separate ssid.
tough to know without knowing what you have.
