OldnSlow
Jul 22, 2023Follower
Connect to second mesh WiFi6 router using existing Nighthawk app
Can anyone help? I have an existing WiFi6 mesh system set up using the Nighthawk app at my primary location. Can I use the same app to connect to another WiFi6 mesh at a different location? If so ...
DexterJB
Aug 08, 2023NETGEAR Moderator
Hi OldnSlow , yes, you can setup a new device in a different location using the same Nighthawk app. Just click on the 'hamburger' menu on the top left of the app > 'Setup a new Nighthawk System' > select the type of NETGEAR device that you'll be setting up next.
Dexter
NETGEAR Team
