sargent
May 10, 2021Aspirant
Connect to Wifi Extender via Mifi
My Internet is via a Mifi Device ( modem) from Vodafone. I have just upgraded the Mifi, the device is working to connect to the internet. I now cannot connect to the extender. (AC1200/EX6130 Wifi R...
- May 10, 2021
on the EX6130, push and hold reset for 7-15 seconds while its powered on. its lights should flash.
That'll get it back to factor and the netgear_ext extension to connect to.
Try that.
The Mifi wifi will need to be one.
May 10, 2021Guru - Experienced User
Try that.
- sargentMay 18, 2021Aspirant
Thank you for taking the time to reply - it did solve the problem.
