sargent's avatar
sargent
Connect to Wifi Extender via Mifi
My Internet is via a Mifi Device ( modem) from Vodafone. I have just upgraded the Mifi, the device is working to connect to the internet. I now cannot connect to the extender. (AC1200/EX6130 Wifi R...
  • plemans's avatar
    May 10, 2021
    on the EX6130, push and hold reset for 7-15 seconds while its powered on. its lights should flash.
    That'll get it back to factor and the netgear_ext     extension to connect to.
    Try that.
    The Mifi wifi will need to be one.
