PW4000
Dec 07, 2012Aspirant
Connect wirelessly two routers
Hi everybody, I want to connect two routers (a DGND3700v2 and a WNR2000v3) wirelessly. The first router has direct access to the internet and to it I connect with two pcs via ethernet. The second r...
PW4000
Dec 09, 2012Aspirant
jmizoguchi wrote: http://vpncasestudy.com/download/WDS/WDS_Concept.pdf
As I wrote on my first post, the wireless repeating function is a way that I already know and I already discarded because of the low security used by that method. So as you see I already searched in the forum.
msnancy wrote:
Set up the router as an access point. Here is a good set guide:
http://kb.netgear.com/app/answers/de...n-access-point
Yes I have already read that link but it doesn't explain how to connect the two router wirelessly, it requires an ethernet cable between the two. I have to place the second router very far from the first, How can I do that?
