PW4000
Dec 07, 2012Aspirant
Connect wirelessly two routers
Hi everybody, I want to connect two routers (a DGND3700v2 and a WNR2000v3) wirelessly. The first router has direct access to the internet and to it I connect with two pcs via ethernet. The second r...
jmizoguchi
Dec 09, 2012Virtuoso
If you don't likely then solution is to BUY EXTENDER
NOTHING. Will change on WDS setup
WN2500RP
WN2500RP
