B-dogga
May 08, 2019Aspirant
Connected to Extender, but no Internet
Hi
Like others I've seen here, I've connected the externder with the router with solid green for both 2.4 and 5 GHz.
I've also got good wifi connection on my laptops, both Mac and PC, and my Sam...
additude
May 09, 2019Virtuoso
It's possible that your equipment is out of range so move it closer together to verify that you are not having any propogation issues.
First, be sure that when you initially setup the extender that the extender was within close proximity (5 - 10 ft) to the router.
After setup, keep the extender within 15 - 20 ft "line of sight" of the router. No walls, no windows, no obstacles between them.
Try to connect your PC thru the extender with everything close to each other and see if you have internet.
- B-doggaMay 09, 2019Aspirant
Had done all that and also used Genie to configure but no use.
Ended up calling my ISP and she talked me through changing IP in the router itself to accept the extender.
Spent half a day trying to work it out and the amazing lack of Netgear support is nothing short of a disgrace.
Certainly won't be recommending Netgear to anybody!!!!!
- plemansMay 09, 2019Guru - Experienced User
so you have it working?
