GillyB
Mar 14, 2020Tutor
Connecting a second extender
Hi, I'm trying to connect a 2nd wifi extender to my router. I have one upstairs which my son's amazon fire stick is wirelessly connecting to perfectly on both 2G and 5G EXT using the same passwor...
- Mar 15, 2020Thanks I'll try that. I was reluctant to turn the working extender off as I didn't want to mess up the extender that is working.
I did the initial set up by the router then took it to the room I needed it in .
