Wapsirat
Sep 29, 2019Aspirant
Connecting an EX6200....
I'm trying to connect an EX6200 to my wifi network. when I try logging in to the NETGEAR_EXT network on my iPhone it asks for a password. What is this password?
Are you asking the wifi password? The label should have the default ssid and password
Or are you wondering default login to the gui?
Are you using wps or manual method for install?
- WapsiratAspirant
I'm using the manual method to connect. The directions tell me to open the available wifi networks in my phone and click on NETGEAR_EXT which I did. A password box then pops up. I tried my wifi network password and it told me that it was incorrect. This brings up my original issue trying to connect the Range Extender. I tried the WPS button method first but the indicators would never turn green so I skipped to the manual method.
have you tried using a different device and/or browser for setup?
