jbastone
Jan 01, 2012Aspirant
connecting machine to wireless network
This is the first time doing this so I hope I am posting in the right link topic I recently setup a netgear G54 WGR614v10 router s/n28T3197B00140 for internet access. I did it thru windows on my Win...
jmizoguchi
Jan 01, 2012Virtuoso
do NOT put serial number in the forum
WEP is HACKABLE.
login the router and properly change the encryption passphrase to your own with WPA2
you probably got hack if had set to use WEP. if you can NOT login the router then reset the router . see router reset on my sig below.
WEP is HACKABLE.
