KeerthiEva's avatar
KeerthiEva
Connecting NETGEAR WiFi 6 Extender to Nighthawk Router with Ethernet Cable
Hi everyone,
I have a NETGEAR WiFi 6 Mesh Range Extender (EAX20) and a Nighthawk router. I'm wondering if I can boost my signal strength by connecting them directly with a wired connection. Can I just use an Ethernet cable, or is there a specific setup I need to follow for a wired connection? Any help on this would be much appreciated!
Thank You,
Keerthi Eva.
  • You can hardwire it in and it will be faster.
    You just have to set it up in access point mode
1 Reply
  • plemans's avatar
