Yooperbug
Nov 21, 2019Aspirant
Connecting router to extender
Can an extender be hardwired to the router and work as it should? We are trying to get Internet to an exterior building. We’re able to run a hardwire but I’m not sure if connecting this way will work.
Nov 21, 2019Guru - Experienced User
Make sure to look at the specs or manual to make sure it supports AP mode. Not all the base models or even 1 step up do.
Yooperbug
Nov 29, 2019Aspirant
Ok, would this work?
TP-Link Wireless N300 2T2R Access Point, 2.4Ghz 300Mbps, 802.11b/g/n, AP/Client/Bridge/Repeater, 2x 4dBi, Passive POE (TL-WA801ND) https://www.amazon.com/dp/B004UBU8IE/ref=cm_sw_r_cp_api_i_oBx4DbG5EKCFR
- plemansNov 29, 2019Guru - Experienced UserNot sure why you're asking on a netgear forum if a tplink will work.
- YooperbugNov 29, 2019AspirantSorry wrong link NETGEAR AC1200 Dual Band Wireless Access Point (WAC104) https://www.amazon.com/dp/B01LFSDZCU/ref=cm_sw_r_cp_api_i_x9y4Db642HG4S
that should do the job for what you've described.
