Yooperbug
Nov 21, 2019Aspirant
Connecting router to extender
Can an extender be hardwired to the router and work as it should? We are trying to get Internet to an exterior building. We’re able to run a hardwire but I’m not sure if connecting this way will work.
Yooperbug
Nov 29, 2019Aspirant
Ok, would this work?
TP-Link Wireless N300 2T2R Access Point, 2.4Ghz 300Mbps, 802.11b/g/n, AP/Client/Bridge/Repeater, 2x 4dBi, Passive POE (TL-WA801ND) https://www.amazon.com/dp/B004UBU8IE/ref=cm_sw_r_cp_api_i_oBx4DbG5EKCFR
Nov 29, 2019Guru - Experienced User
Not sure why you're asking on a netgear forum if a tplink will work.
- YooperbugNov 29, 2019AspirantSorry wrong link NETGEAR AC1200 Dual Band Wireless Access Point (WAC104) https://www.amazon.com/dp/B01LFSDZCU/ref=cm_sw_r_cp_api_i_x9y4Db642HG4S
- plemansNov 29, 2019Guru - Experienced User
that should do the job for what you've described.
