cloudcover
May 21, 2019Aspirant
connecting to mywifiext.net
My EX2700 range extender was working fine, until I lost internet service for a few days. When internet service was restored, the EX2700 no longer worked. I tried to reset the connection to no avail...
cloudcover
May 22, 2019Aspirant
I am not a tech expert. I do not know what firmware the EX2700 has installed nor my modem. I know that I purchased the extender in 2017 so I assume it is not the latest firmware. the lights that are lit are the power and the WPS light and they are both solid green. the device and router lights are not lit.
I have rebooted as per your instructions. I have hardwired the device to the laptop. However I cannot access the website. Even though I can access the internet from the computer I am using and can use my email and other websites, the mywifiext.netsite does not come up (I mostly get an error message - too slow to connect). When I am able to connect, I get a login page which does not accept my login nor the admin/password login that the instructions say should be acceptable.
As per directions from the manual, when I connect an ethernet cable to the LAN port of the EXT and the LAN port on my computer the LED should blink. Which LED? There are only 4 on the EX2700. 1. Power 2. WPS 3. Device 4. Router
There is no change in any of the LED lights. The first 2 are solid green and the other 2 are dark.
Thank you for your patience
Cloudcover
May 22, 2019Guru - Experienced User
If you're leaving your wifi on when you connect to the extender, your computer is defaulting to that connection. Try this route.
1. Download the most current firmware for your device. Extract it to your computer so you have it for later.
2. Hardwire into the extender.
3. Shut off the wifi on your device you're connecting to the extender.
4. Now try the mywifiext.net
Were you able to get to the login page?
If you're fully reset the device the login of admin and password of password should work. If it doesn't, try resetting it again. while its powered up, hold the reset button until the lights change. (shouldn't take more than 7-10 seconds but hold up to 30 if lights aren't blinking)
