dolceveta
Dec 13, 2021Follower
Connecting to Newer Spectrum Gear
hi - recently attempted to connect this wi fi ext. to a Spectrum modem/router and the WPS button doesn't blink like with older generations of Spectrum/TimeWarner equip. Can this extender be 1)update...
Dec 13, 2021Guru - Experienced User
instead of setting up using wps, setup the extender using the installation assistant.
Factory reset the extender (push and hold reset for 7-15 seconds) and then use the installation assistant.
Don't use WPS
