pjcinmtns
Sep 22, 2021Aspirant
connecting to WN3000RPv3 auto-switches to https and fails
Folks, I have an N300 Range Extender (WN3000RPv3) and haven't logged in for quite awhile. Client devices connect just fine but I cannot get to the admin screens. I want to update the firmware. In...
- Sep 30, 2021
Since I seem to be chatting with myself here, I will continue as someone may search for a solution and my notes may help.
I did not want to purchase a premium support session and I did not want to factory reset the extender with a straightened paper clip. With the reset, I worried that I might lose the successful client connections as I tried to login to the admin screens. So, I purchased a new extender, it arrived, and I did the reset on the existing extender. I set it up as if new following the instructions. I found that I still could not connect to the admin screens. But, newly setup I found that this time I could connect using its IP4 numbered address that I got from my router devices listing. So, the sequence is: laptop chooses the NETGEAR_EXT network SSID, I connect using the IP4 address, and I'm in.
If interested, I purchased a Netgear AC750/EX3700 Wi-Fi Extender and I installed it as a replacement. The N300 will remain in reserve. I have my notes if I need to swap this unit out at some time.
By the way, after i upgraded the firmware following the prompt on the new unit, I wandered around and found a check box setting to "always connect with https." I checked that, power-cycled the extender and I can now use the 'mywifiext' named address to login to the admin screens. As mentioned earlier, current web browsers will expect 'https' rather than 'http' connecdtions.
pjcinmtns
Sep 23, 2021Aspirant
Quick update... I dug thru my old setup notes and screen captures and found that I do have the latest firmware installed on the unit, 1.0.2.86. I updated it in December 2020.
I continued to try different approaches to get a successful admin login. (The clients connect to the home LAN via the extender with no problems.) I used a direct Ethernet cable connection with Wi-Fi disabled. No success. I tried its IP address with no success. Since browsers now auto-switch to https, I went thru a long process to install the command-line, text-based lynx browser. It allows ' http' connections. It also failed.
What started all this is that my wife was unable to connect in that part of the house where the extender provides access. I power-cycled the unit, she connected, and I thought that I should check operation, settings, and firmware. I could not connect to the admin pages. I checked my notes and visited the support site and began my--so far unsuccessful--journey.
Any suggestions would be appreciated.
pjcinmtns
Sep 30, 2021Aspirant
