tagluca
Jul 02, 2013Follower
Connecting two WN2500RP
First of all sorry for my english. Let me first explain my situation, i have a three level house with the following configuration (I don't have the possibility to cable or use the electrical line, ...
ChristianS
Aug 31, 2014Tutor
Just a suggestion.
Have You checked that the 2 Range Extenders does not choose the same SSID? This will Ruin Your WIFI for sure
Example Your Main Router SSID is "NETGEAR".
Both Range extenders will by default choose NETGEAR_EXT as their SSID.
Change the SSID of one of the extenders to say NETGEAR_EXT2
This may help You.
Best of luck to You my Friend.
ChristianS
This may help You.
ChristianS
