jojo57
Jan 06, 2013Follower
connectingtwo netgear wireless routers
I have a netgear N600 router, a wmdr 4300 N750 netgear router. i have roadrunner and have the roadrunnermodem,, connected to that is the 4300 n750. I have that set in my main part of house. I have...
jmizoguchi
Jan 07, 2013Virtuoso
If you can use Ethernet cable between the two then use AP mode on second unit in the router GUI
AP mode in the GUI uses Internet port out to existing LAN and disable firewall
If you are looking to setup two router wirelessly then I do not recommend as security will be WEP/54Mbps or no security
Use extender like wn2500rp
