CappedOmnivore
Nov 03, 2022Tutor
Connection issue with EX6150v2 range extender
I am actually having 2 separate issues but I believe they are connected. I use a Netgear EX6150v2 range extender in my home. Sometime ago an issue arose where even when I turn it on, it will connect ...
Nov 04, 2022Guru - Experienced User
what router is the extender connected to?
what firmware is on the extender?
Did you set up the extender using wps or using the installation assistant?
- CappedOmnivoreNov 06, 2022Tutor
The extender is connected to a Nighhawk R7000 router.
I'm not sure of the extenders firmware version since I can't get into it on the app.
And I set it up using WSP but I did that well over a year ago and nothing else has changed. It just started doing all this out of nowhere.
