CappedOmnivore
Nov 03, 2022Tutor
Connection issue with EX6150v2 range extender
I am actually having 2 separate issues but I believe they are connected. I use a Netgear EX6150v2 range extender in my home. Sometime ago an issue arose where even when I turn it on, it will connect ...
what router is the extender connected to?
what firmware is on the extender?
Did you set up the extender using wps or using the installation assistant?
CappedOmnivore
Nov 06, 2022Tutor
The extender is connected to a Nighhawk R7000 router.
I'm not sure of the extenders firmware version since I can't get into it on the app.
And I set it up using WSP but I did that well over a year ago and nothing else has changed. It just started doing all this out of nowhere.
