LarsCH
Nov 02, 2024Follower
Connection to EX7000
Can I connect another wifi router or extender after (in series with) the EX7000? I have an ethernet cable I can use from the EX7000. Wifi router to EX7000 is working wireless OK but from EX7000 to ne...
Nov 02, 2024Guru - Experienced User
so you're planning on going:
Router------wireless------>EX7000-----wired------->another extender/router
Is that correct? If so, yes, you can do it. I wouldn't recommend doing a daisy chain over wireless but going wireless then wired would be fine.
