silverstar1
Nov 07, 2021Tutor
Connection to Router Issues
My nighthawk extender EAX20 (AX1800 4-Stream Wifi Mesh Extender) is no longer connecting to my router. I have changed my router password but it still keeps saying it cannot connect. Help please ?
Nov 07, 2021Guru - Experienced User
what router do you have?
have you tried factory resetting the EAX20 and reinstalling using the installation assistant?
silverstar1
Nov 07, 2021Tutor
It’s a huwaii router.
All my other devices are connecting in except for the nighthawk. I haven’t done a factory reset yet
- plemansNov 07, 2021Guru - Experienced User
Try the factory reset and reinstall using the installation assistant and NOT wps.
- silverstar1Nov 07, 2021TutorWill do thanks very much
