OmerGuven
Jul 17, 2022Aspirant
Connection
I am trying to connect my Netgear EAX15 to the Nokia FastMile 5G Gateway 3.2 …. but it is not possible even though the password for the Nokia is for sure correct …. With other router the EAX15 connect...
OmerGuven
Jul 18, 2022Aspirant
I set it up through the app of netgear and it works with another router but not with the Nokia one.
WPS I am not aware of how to use it and what the effect would be ...
Jul 18, 2022Guru - Experienced User
Try factory resetting the extender and installing it using the installation assistant.
You might also see about setting it with a static ip address in the nokia.
