jruvang
May 31, 2022Aspirant
connectivity ax1800 issues
My computer, my wife's and friends iphone all find and connect with password to my netgear extender. However, my iphone (same updated op) and smart tvs, all easily within range, find the extender bu...
May 31, 2022Guru - Experienced User
what router are you connecting it to?
did you set it up using wps or using the installation assistant?
Also, what extender is it? AX1800 is a speed, not a model.
- jruvangJun 01, 2022Aspirant
Hi, thank you! The model is EAX20 and it is connected to a new Frontier Communications router via CAT5 cable. It was interesting that by the time the extender powered up, my laptop recognized it and connected. This made me concerned about security, so I went in to set up a password. That went fine and my computer connected with the password as does my wife's and friend's iphone. It's only my iphone and two smart tvs that won't connect. Re: set up, other than adding the password, nothing else has been done. Btw - the reason that I bought the extender and new tvs, etc was due to a lighting strike. That strike killed my computer CAT5 input card, so I needed a quick fix for my work connectivity.
- plemansJun 01, 2022Guru - Experienced User
So the EAX20 is hardwired into your router?
did you set it up in access point mode?
You changed the ssid/password on it or left it default?
Make sure there isn't any special characters or spaces in the ssid/password.
Did you try disabling AX on the extender? Its been a while but I've seen some older devices with issues connecting to AX. Usually you can update their drivers directly from the manufacturer and they work but an easy test is to disable AX.
Yes, it is hardwired. I have tried ext mode as well as access mode. Access mode works well for my computer.
ssid password remains default.
I've tried to disable AX.
It's interesting, my wife's iphone is older than mine. We both have the same updated software. Hers works, mine does not. (Nor will the smart tvs.)
Thanks for your help. I will be returning this and starting over with a different version.
