Fir3
Nov 07, 2020Aspirant
Connectivity Issues with EX7000
I keep running into issues with my EX7000 when connected via Lan. Whenever i boot up my PC (Win10) I seem to not be connected to the Internet. Logging into the Extender shows both 2.4 and 5 GHz con...
Nov 07, 2020Guru - Experienced User
what router are you connected to?
Have you tried setting the extender with a static IP address from your router?
You've tried installing it using the installation assistant? (instead of wps)
antinode
Nov 07, 2020Guru
> router?
Terminology: A "static" address is configured on the device itself.
What you configure on a (DHCP server on a) router is a reserved dynamic
address, not a static address.
If it's "from your router", then it's a reserved dynamic address, not
a "static" address.
