Fir3
Nov 07, 2020Aspirant
Connectivity Issues with EX7000
I keep running into issues with my EX7000 when connected via Lan. Whenever i boot up my PC (Win10) I seem to not be connected to the Internet. Logging into the Extender shows both 2.4 and 5 GHz con...
Nov 07, 2020Guru - Experienced User
what router are you connected to?
Have you tried setting the extender with a static IP address from your router?
You've tried installing it using the installation assistant? (instead of wps)
Fir3
Nov 09, 2020Aspirant
Yes I did try using the installation assistant as well, but sadly end up with the same result.
When it comes to setting a static IP i gotta be honest that i dont really know much about managing my own network so I ll try to read into that when i have the time.
As for the router, its just a generic base router I got from the ISP here in Germany, no aftermarket product.
