Culvennan12
Mar 05, 2020Aspirant
Connectivity Nighthawk EX 7300
My extender will not accept the network security key when I am attempting to connect my laptop. When I address the available channels on the drop down menu I see" Netgear 54" and not "Netgear ext" t...
- Mar 05, 2020
Newer Netgear devices come with randomly generated default SSIDs - both the default SSID and PSK (wireless/network security key) are printed on the label. Doubt somewhat that there is a space in the default SSID. Before it was e.g. NETGEAR_EXT ... this is what is in the curent extender user manuals, too. You might want to factory reset your extender in case it was connected/linked to another network, and restart the config from scratch.
Culvennan12
Thanks,sounds like a plan.Not looking forward to a new config.I am a little out of date,I arrived on the scene when BIG Blue built the IBM 1 personal computer,I think I need to update my knowledge a little!
Culvennan12
Mar 12, 2020Aspirant
Hi Dexter
Thanks for your reply it is very useful to have the support of a knowledgeable community.The exercise has thrown up to significant issues.
1) The ISP (Sky) is in breach of contract roviding variable wifi connections to a fibre link of 15 to 20 mps.
2)The Open Reach circuit provider is regarded to be at fault since the router is tested as satisfactory.
3) The drop down channel list ion my Dell 13 laptop is showing Netgear 54 not Netgear_ext,
the smart setup genie is showing me to be connected to 2.4Ghz channel on the router so that is good enough for me.The difference between the academic and the real world when it comes to technology continues to surprise!
Culvennan12 wrote:Thanks,sounds like a plan.Not looking forward to a new config.I am a little out of date,I arrived on the scene when BIG Blue built the IBM 1 personal computer,I think I need to update my knowledge a little!
