blakegriggs81
Jul 01, 2022Aspirant
correct password but unable to join network EX7000
I recently installed a new router and reset my netgear night hawk ex7000. Connected the night hawk to the new router using wps. The night hawk is showing two ext networks. One being a 2gext and the o...
michaelkenward
Jul 18, 2022Guru - Experienced User
How are you trying to connect to this thing?
Past messages don't tell us if it is a mobile device or a PC.
All we have is "Every device i try to connect to the 2gext network says unable to join."
Also, beyond saying "couldn't connect" we know nothing about the error messages that you see on whatever it is you are using.
And what router are you connecting it to?
- michaelkenwardJul 18, 2022Guru - Experienced User
Der. I forgot that one.
