Dustin_V
Jun 22, 2018NETGEAR Employee Retired
Create a WiFi Mesh System with the NEW Nighthawk EX7700 Mesh Extender
Experience super-fast WiFi mesh with the latest member of our Nighthawk Mesh Extender family! The new EX7700 allows you to create powerful whole home WiFi using your existing WiFi. Wit...
Mickbashala
Sep 24, 2018Aspirant
Thanks
bamabillyp
Oct 14, 2018Tutor
Before the "single wifi mesh" I was able to see my 2.4 and 5 ghz radios and manually selected them. I had great results, especially when selecting the 5ghz radio and was getting ~200 Mbps in areas I previously would only get 10-20. After the latest firmware and using the "single wifi" name, it does not seem to be choosing the faster 5 ghz radio. I do my tests in the same area and it seems to only be selecting the 2.4 radio. I see the client light so I know I'm using the extender but getting 2.4 speeds. Why is it not selecting the faster radio? Can I go back so I have the option to manually select the 5ghz radio? Why would it not select that automatically ?
