mmcglynn264
Mar 11, 2020Aspirant
Creating wifi mesh by adding to existing router
As stated above, I have the NETGEAR Nighthawk X6S AC4000 Tri-band WiFi Router. My house is 1600 sf with a large rear deck and a detached garage. I have a travel trailer next to garage that I want to ...
mmcglynn264
Mar 12, 2020Aspirant
Interesting. So my r8000p router is cannot act as part of the mesh as if it's the orbi router? My biggest issue there is that I use all 4 ethernet ports on my router. That's how I'm able to use the access points. So basically, the only way to get true wifi mesh covering the same areas as my current setup with a main router and 2 ap, with ethernet backhaul is to go with entire orbi setup?
Mar 12, 2020Guru - Experienced User
R8000P isn't orbi and can't function as an orbi router.
In terms of the ports-- you can get a cheap 4-8 port gigabit switch for usually around $20
You're correct. to get a true mesh system, you need to move to mesh system. Not just naming ssids the same. And the only routers that function as actual mesh is Orbi.
Again, there are extenders that ACT as mesh but its more of a hybrid setup and isn't true mesh like you're wanting.
