MathieuEX8000
Jan 21, 2020Aspirant
Débit faible en ethernet EX8000
Bonjour, Je viens de mettre en place le répéteur X6S EX8000 connecté en wifi avec ma box SFR fibre. l'idée est de redistribuer la connexion wifi sur mon PC fixe, et ce en ethernet. L'appairrage...
MathieuEX8000
Jan 22, 2020Aspirant
Hello,
Thx for your answer ! :)
Smart connect is not activated because i have activated One Wifi Name (both can t be activated at the same time).
You might be right with the backhaul because wired (or not) speed is the same (around 35MB/s). I préceise that the speed conection led is white (so the best case) and it s the same whatever the distance.
By the way, if I turn off the EX8000 wifi speed is about 400 MB/s / at the same place 35MB/S with the extender.
I tried the last 3 FW (now it s runing the 1.0.1.206). I tried a hardreset after each update.
The routeur is my operateur materiel which deliver an Wifi AC1300 (it s identified as it by the EX8000). Not sure there is a QoS. All other Wifi equipment works fine.
I m pretty sure that the backhaul is the right issue to fix, cause it looks like if the extender only deliver 2.4Ghz speed but how can i manage it?
Thx for your help!
Jan 22, 2020Guru - Experienced User
It doesn't mean that the backhaul is the issue. It just means that you've narrowed the problem to either the router or the extender backhaul.
when you setup the device, did you use wps or the smart installation wizard?
What model is the fibre box?
- MathieuEX8000Jan 22, 2020Aspirant
Thx again :)
I tried to use both WPS then Wizard with the same effect.
I really don tget why it s limited either Wifi and ethernet (maybe i have to change the 5Ghz Chanel?).
My box is as describe in the following doc.
- plemansJan 22, 2020Guru - Experienced User
A couple things and thoughts.
1. Try hardwiring in the EX8000 and running it in ap mode. See how it functions for testing.
2. I imagine you're using the europe region for the ex8000. I'm not sure on broadcast restrictions for 5ghz channels. I know its more strict than US. I also know that in 2018, support was added to the ex8000 for DFS channels in the US. Again, not sure on the europe side of those settings. This makes it a little challenge.
here's what I'd try. Rerun the setup from factory. (factory reset the device). During setup, you can deselect the 2.4ghz radio. do that. that'll make sure only the 5ghz channel connections. Set it up using just the 5ghz so it doesn't fall back to the 2.4ghz. Once its setup, rerun both a hardwired speedtest and wireless speedtest (on the 5ghz band).
- MathieuEX8000Jan 23, 2020Aspirant
Hello,
What i tried:
=> It works i reach normal speed download and upload
=> First of all i notice that factory reset doesn t work with button and WPS connection doesn t work too / i have to use wizard to manage the configuration. That said, i have tried:
to configure without 2.4ghz => it doesn t work
to configure without 2.4ghz and without One name Wifi => it doesn t work
to configure with 2.4ght and without One name Wifi => it doesn t work
Speed is always at the same limit 35MB/S download ans 58MB/S upload.
It s amazing, do you have any suggestion?
THx :)
