Jcyshin
Dec 27, 2021Aspirant
D6300 issues setting up as AP
Hi Guys, I recently purchased a D6300 and thought it might be good to use it as an AP and bring it into my Fritzbox Mesh network, however I am running into a few problems. After reading close to 5...
- Jan 03, 2022
Hi Jcyshin
Jcyshin wrote:
3) 2nd attempt at the Genie App `interface, I chose 'No' and went through the settings myself. Within the Genie App I left everything the same, didn't change the SSID, didn't change the password. The only thing I did was set the D6300 to 'AP Mode' under advance settings.
This is the only way to bring these xDSL routers to an AP configuration, being on the D6300 or on the D7000v2. (Documented in the RT*M for the D6300 p.99 ff. resp. the D7000v2 p.91 ff.). The "captured" Genie Assistant is made for establishing a router config on this xDSL router, probably even only for the ADSL, VDSL, VDSL2, ... Internet connection (otherwise the connected "Internet" relsp special LAN port 4 on the D7000v2 port would be recognized and it would be set-up as a NAT router). At that point, the designated Ethernet interface for the AP operation is the one shown in the RT*M, marked WAN.
One would expect it is able to get an IP config from the Ethernet connected Fritz router, and you should be able to reach the Web interface on that IP address from your normal LAN or WLAN.
Ignore the partial misleading "10. To reconnect, close and restart your browser and enter http://www_routerlogin_net. " - this can only work if the (plain text) DNS query does pass that device, eg. while you are connected to the Dxxx WLAN.
Jcyshin wrote:
5) I then unplugged the LAN Cable above and tried to see if it would work as a wireless AP or not.
This is where your misconception does start: A Wireless Access Point (AP) is by common definition always a bridge between the wireless and the wired network - it must be always connected to a wired network. You can't disconnect a "normal" from the wired network - it won't become magically a wireless repeater, or Mesh member of your proprietary AVM Fritzbox 7590 (MeshMaster) system (nor any other Mesh system like a Netgear Orbi, Orbi Pro, ...) and act like a Fritzbox 7490(Mesh Repeater/AP). It is what it is with this "third usage" config: A Wireless AP.
The same applies if you run your D7000v2 as a xDSL modem and router. The D6300 can only be connected as a wired Wireless Access Point. And yes, unfortunately has missed the opportunity for adding Mesh funtionality to older WiFI devices.
olympos1625
Dec 28, 2021NETGEAR Employee Retired
Hi Jcyshin,
Thank you for reaching out. Please allow me to gather details on your setup.
1. Did you connect the Fritzbox to Netgear to the WAN port of the D6300?
2. What is LAN IP address are you getting when connected to the Fritzbox?
3. What IP address range did you set to static to D6300?
4. What is the current firmware of the D6300?
Please do not hesitate to let me know if you need further assistance.
Oliver
Community Team
Jcyshin
Dec 28, 2021Aspirant
Hi Oliver
Thank you for trying to assist me with my enquiry:
-As the D6300 is a slightly older ADSL Modem, it doesnt' have a WAN Port. Instead what it has is an 'Internet' port, 4 x LAN ports, 'ADSL' Port and a few USB ports, I connected the LAN cable to the 'Internet' port of the D6300(figured it was more or less a WAN port compared to current routers), The other end of the LAN cable went into port 3 of my FritzBox 7590 which is the main Router/Modem for this household. Fritzbox 7590 has a LAN cable from the WAN port to the Fibre box. Basically, I currently have a Fritzbox Mesh 7590 & 7490, purchased this D6300 as it was a good modem in the day so thought I would use it as an AP.
-LAN IP for the fritzbox is 192.168.178.1 as per recommendations from my ISP,
-IP Allocation to the D6300 was 192.168.178.3 as it was allocated by the Fritzbox 7590.
-Firmware Version V1.0.0.102_1.0.102
- plemansDec 29, 2021Guru - Experienced User
You haven't put what error you're getting or what issue you're running into with it connect.
Got a few more details on this?
