david1928
Jul 12, 2020Aspirant
D6400 - won't find NG AC750 WiFi Extender
D6400 (it's 3+ yrs old but up-to-date firmware) won't find brand new NetGear AC750 WiFi Extender network.
Already done:
=reset Extender (7 sec hold ==> green light returned)
=refreshed NetGear connection manager several times
=rebooted D6400 (unplugged x 20 sec).
= D6400 Manual doesn't specifically address whether it's capable of connecting to Extenders in general.
Thoughts?
usually you connect the extender to the router.
What extender is it? AC750 is a speed.
Firmware on it?
- david1928AspirantIt's NetGear's Model EX2800.
Thank you. - david1928AspirantIt's NetGear's Model EX2800.
Thank you. - david1928AspirantIt's NetGear's Model EX2800. Until i can connect it to my system I can't connect to it's software.
Thank you.- plemansGuru - Experienced User
Factory reset the extender by pushing and holding reset for 7-15 seconds while its powered on.
then you should be able to follow the smart installation wizard for the Ex2800. https://www.netgear.com/support/product/ex2800.aspx
