JamesD7000
Feb 09, 2023Tutor
D7000 - Build Mesh with EX8000
Hi, Extremely happy with my D7000 Netgear, only concern is to extend range to cover the garage BUT WITH the same SSID in other words can the D7000 Netgear manage a mesh network ? ... Could the Ext...
- Feb 09, 2023
JamesD7000 wrote:
But the current extender I have has created another network, and it so cumbersome to switch permanently that I have removed completely ...
I don't know what this "current extender" is so cannot advise on whether you can give it the same SSID as the D7000.
All I know is that this works on my R7800 in AP mode. Not that it is something would do because I see no point.
My objective is to extend my range substantially With a Unique SSID ... and my understanding is that the only solution is a Mesh solution ...Like I said, you can use the same SSID on different devices on the network but it won't be Mesh. To get that you need a router that supports Mesh and compatible satellites.
Netgear has a raft of Mesh devices. That is what Orbi is all about. Then there are the "MK" devices.
Mesh WiFi Network: Routers & Systems | NETGEAR
Your D7000 is a DSL modem/router. If you need that for your Internet connection, you can put it into modem only (bridge) mode and add a Mesh router network.
JamesD7000
Feb 09, 2023Tutor
Thanks a lot for your answer.
May I take advantage of your knowledge ...
1. You are saying the EX8000 could work with my Netgear D7000 as a range extender
and
2. Nothing prevents me from using the same SSID
Is that right or not ?
Thanks for your kind assistance
michaelkenward
Feb 09, 2023Guru - Experienced User
- JamesD7000Feb 09, 2023Tutor
Thanks a lot for all your explanations 😀
