Larry_McCarthy
Jan 09, 2022Tutor
Daisy Chaining Extenders?
I have AT&T Uverse, incl. internet. I am using a NETGEAR Model EX6400v2 mesh WiFi extender to let me go online out in my room, since the AT&T router's WiFi signal doesn't reach out here or, when it d...
Jan 09, 2022Guru - Experienced User
Can you daisy chain extenders? yes.
Should you? Debatable.
Reason why is standard single/dual band extenders drop throughput by 50%. this happens because they have to use the same chip to go router---->extender and then extender------>device. And they can't do both at once. so it cuts speed in half. And thats half of what it recieves. So if its already at a decreased signal because of distance/obstruction/interference, that 50% can be more significant.
If you have to do this, you'd want to try to use a triband extender to be the middle device. the tribands have a dedicated band for just router---->extender. This helps keep that speed reduction down. but it still increases latency.
We usually don't recommend this because it can still be a bit unstable.
If you're needing more than 1 extender, we usually recommend moving to a full triband mesh system like orbi or the MK83 nighthawk.
Larry_McCarthy
Jan 09, 2022Tutor
Thanks very much, plemans. I will look into the orbi and MK83 Nighthawk options.
