Larry_McCarthy
Jan 08, 2022Tutor
Daisy Chaining Extenders?
I have AT&T Uverse, incl. internet. I am using a NETGEAR Model EX6400v2 mesh WiFi extender to let me go online out in my room, since the AT&T router's WiFi signal doesn't reach out here or, when it d...
Larry_McCarthy
Jan 18, 2022Tutor
Thanks again, plemans, for your previous reply. The orbi system and the Nighthawk MK83 system both use Wi-Fi 6. I have read that 6 GHz Wi-Fi is not as good at penetrating obstacles as 5 GHz, which is not as good (for this purpose) as 2.4 GHz. I have serious obstructions. Do yoiu think Wi-Fi 6 will be a problem?
Jan 18, 2022Guru - Experienced User
There's a difference from wifi 6 to wifi 6e.
Wifi 6 is just 2.4ghz and 5ghz
wifi 6E uses 2.4ghz, 5ghz, and 6ghz. The 6ghz doesn't have the broadcast power/penetration power that 2.4ghz/5ghz does.
- Larry_McCarthyJan 19, 2022Tutor
Thanks, plemans. I did not know that.
plemans wrote:There's a difference from wifi 6 to wifi 6e.
