Lala2323
Mar 19, 2020Aspirant
Daisy Chaining
Looking for knowledge before I attempt the install. Looking to boost our wifi purchased two routers: NETGEAR Nighthawk X6S AC3600 Tri-Band Wi-Fi Router NETGEAR - Nighthawk X4S Dual-Band AC2600 Rou...
Mar 20, 2020Guru - Experienced User
actual model numbers help.
but if ones a combo device, you need to go combo device------router (in ap mode)
best bet is to hardwire them together.
- Lala2323Mar 20, 2020Aspirant
Model number R7960P-100NAS
I am just going to use two of these routers. do you know if there is any documents for step by step walk throughs?
thank you for your help!
https://www.costco.com/netgear-nighthawk-x6s-ac3600-tri-band-wi-fi-router.product.100484415.html
