Lala2323
Mar 19, 2020Aspirant
Daisy Chaining
Looking for knowledge before I attempt the install. Looking to boost our wifi purchased two routers: NETGEAR Nighthawk X6S AC3600 Tri-Band Wi-Fi Router NETGEAR - Nighthawk X4S Dual-Band AC2600 Rou...
Lala2323
Mar 20, 2020Aspirant
ok awesome ideally i would to seperate them and connect by wifi to extend range
Mar 20, 2020Guru - Experienced User
then you'd want an actual range extender and not 2 routers. get the one router and a triband extender that does mesh and you'll be better suited than buying 2x routers.
you'd be better off to look at mesh systems as they're more easily expandable and usually cheaper than buying a router and a range extender. especially since amazon has been running refurb/renewed specials lately.
